cluch problem
stars
Hey a piece of clutch door holder chipped off, and i do have the chipped off piece, but was wondering do you think i could glue it back together or something or just replace the engine?
depends on your skills - I've fixed those by cutting a piece of 1/8in steel to wrap around the casting for the drive shaft behind where the missing part is, then bolted that steel to the case & drilled out a hole for the cover bolt - I threaded the missing piece on that bolt just to make a seat for the cover
probably too much work for the average user of these
tried many glues and epoxies, some of official aircraft grade, just to stick that broken piece into place where it met the steel - nothing could hold against the vibration & force of clutch arm - didn't try welding tho
clutch arm pushes hard there - I'd at least drill a hole for a bolt to go thru between top & bottom chain run to help hold it together - the other two will break quickly if they try to hold the entire load
i have another engine that i can rebuilt with the parts off this engine. that will save me all the bs. thanks anyway
