Clamshell doesn't quite fit
thxcuz
I got a clamshell sproket mount off eBay and it doesn't quite fit. It's supposed to be 1.5 but it doesn't quite fit on my hub. My hub could be a mm or 2 larger.
Can I grind the clamshell a little to make it fit?
Do you mean there is a gap between the two halves when assembled on the hub? because that is normal.
if you mean the adaptor will not slide onto your hub i would double check the mesurements with a caliper and possibly even try to get the seller to replace it with the right size.
if the difference is enough that you think it would require more than a light sanding to make it fit you should get a machinist to do it for you.
good point - happens with noobs doing motor mounts too - got to explain to them that anything that clamps around something needs a sufficient gap when tight to be sure it is tight and not just bound together with itself
