wtwrestling07
I have quick question. I have a 80cc/66cc engine I bought off of ebay from rose32 about a year or so ago and I ran it on the bike about 2 tanks. I didn't even finished breaking it in yet and ended up taking the bike apart and taking a welder and grinder to the bike.
I turned it into a lowrider/cruiser bike.
Soon I will be putting the motor back on, except before I do, I am going to be doing some heavy modifications to the motor like Port matching/possibly more grinding depending on how it goes, billet head, billet tapped intake, boost bottle, performance carb, and exhaust from sbp, and some other stuff. My question is should I open up the crank case and change out the clutch/crank case bearing and wrist pin bearing to hd bearings before I do all the modding because I dont want to do all this work and then the bearing mess up because of all the modding. Or do you think because it is basicly brand new it should be alright with the bearing that are in it. The bike is mainly going to be a show/cruising bike. I might take it down the road a few times and see what its got after I do the heavy modding.
After that it will probably be just for taking a cruise every now and then except mainly a show bike. I have seen a few tutorials on how to change out the wrist pin bearing/clutch/crankcase bearings and it seems fairly simple and HD ones are some what cheap. It might also be a pain in my neck and after I get it open I might end up wishing I hadn't opend the damn think and end up needing a new motor. So basicly has anyone ever changed out the bearing and is it alot of work or no? or is it worth the hassle of changing the bearings or do you think it will be fine without. Also I saw a copper casket set for sale somewhere for 66cc and if I open up the motor I will be putting on a new gasket. Do you think the regular gasket or copper gasket set would be better for a med/heavily modd 66cc
