Chain to clear rear tire
Jamesgregory
I would like to throw this out here for some input or ideas. I am working on running Maxxis tires and they are 2.5 wide (I already have them on). The wheel needs to be pushed over and the sprocket brought out a bit. I’m thinking of spacer washers or thin nuts threaded on the chain side rear wheel axel to push the wheel over and spacers on the bolts between the sprocket and hub adapter. Any thoughts or input would be appreciated
How much room do you have between the tire and the stays and chain on the pedal side? It may be possible to dish the wheel to the right (offset from the hub) in order to gain clearance for the drive side chain.
I had this issue on my china build. the easiest and best fix is to use a thinner tire. I used the maxxis 1.9x26 hookworm.
James, I dig the fact that you are using 2.5" tires. I'm using 2.35" Schwalbes on both of my current motor-bikes. For most frame, a 2.5" tire would be a tight fit!
-Consider a Manic Mechanic Hub Adapter, which allows for side-to-side adjustment/movement, in addition to keeping the rear sprocket perfectly true.
-Adjust the rear wheel so it just barely clears the pedal-side chain, in order to allow maximum space for the engine-side chain.
-If neccessary, also consider a standard, KMC-brand 415 chain, as opposed to the 415H chains that come with the engine kits. the 415 will still fit the sprockets you have, but has less width than a 415H, with minimal tensile strength difference. This will give you a slight advantage for tire clearance, though it is a slightly weaker chain.
If all else fails, maybe a Sick Bike Parts shift kit, so you only have the pedal chain going back.
Im running 2.35 Schwalbes (Fat Frank) on my Mountian Bike, I like them so far I only got them last week and put them on. They dont look to much smaller than my Maxxis I do have the hub adapter and going to run a 40T sprocket. Turbobuick1 when you say "-Adjust the rear wheel so it just barely clears the pedal-side chain, in order to allow maximum space for the engine-side chain". What do you mean by this and how would you adjust a tire over???
I guess what I'm trying to say is, when you mount the rear wheel and tire to the bike, instead of having the wheel pointed directly at the seatpost, have it slightly angled towards the pedal side chain. Obviously you would be adjusting this as you tighten down the axle nuts. I hope this makes sense! Let me know if it doesn't. I had to do this with the motorbike fitted with Schwalbe Fat Franks. I was able to use my 415H chain, but with your 2.5" tire, you might have to resort to the 415 chain, but of course this also depends on your bike frame. Post up some pics when you get a chance, Id like see just how wide that tire is!
Angling the rear wheel is not a good idea. If the engine is centered in the frame as its supposed to be, angling the rear wheel will throw off your sprocket/chain alignment. That's asking for problems. The drive and driven sprockets should be exactly aligned with each other for proper roller chain performance and to reduce the risk of derailment.
You can install washers between the frame and the rear hub to spread the chain and seat stays a little IF your axle is long enough to allow it. Very slight chain to tire interference won't hurt anything. Whitewalls can get a little messy but unless you're showing signs of tire sidewall wear at the point the chain hits, don't worry about it.
Keep you chain tension right, 1/2 to 3/4" slack and you should be good.
Here is a picture of the bike right now. Im having a motor mount fabricated to raise it a bit. Does that give an idea of how wide? I have Fat Frank on my first with only 2 washers on the axel. I like them
As long as you're going with custom engine mounts you might want to consider off-setting the engine slightly to the left. The Nirve Switchblade uses a 3.5" rear tire and requires the engine be shifted to the left 9/16" to get everything to clear. Both front and rear mounts must be custom fabricated.
The angling is so slight, it is harmless. I have had 328 GPS-recorded trouble-free miles since installing these larger tires with absolutely no problems with the chain. While I do agree that any chain on any machine should be aligned well to minimize excessive roller pin wear, ALL chains can tolerate very slight misalignments.
