The #415 chain supplied with my Gasbike GT80 kit gets stuck in the engine drive sprocket. To get it loose I have to drive it out with a hammer and dowel rod. The sprocket is a 10 tooth. The chain is not contacting any part of the engine case and the cover is off. This happens when I rotate the engine gear with a flat blade screwdriver and try to thread the chain on the drive sprocket. The chain works fine on the rear wheel sprocket.
Any thoughts? Thanks
