SuperDave
This is a trick my dad taught me as a kid: Use a crayon to lubricate the chain. Friction of the moving parts will heat the wax and penetrate the pores of the metal, providing lubrication. It also helps reduce chain noise. It will coat the parts with wax, helping to deter rust. It won't attract dirt, and if your bike lacks a chain guard, it won't sling off & stain your pants. I hold the crayon against the chain so it coats it where the chain meshes the gears and hand crank the pedals. I also rub the crayon on the sprocket teeth to coat them thoroughly.
I have taken this one step further, I rub crayon on the gears under the clutch cover. Unlike grease, it won't sling off easily or ooze down under the pressure plate or get on the clutch pads to allow slippage. I have noticed it does an awesome job minimizing gear noise as well. Any color or brand of crayon works. It may help reduce maintenance to those parts, reduce noise, minimize rust & corosion, and extend the life of your motor & bike.
I have done this to both the pedal chain, the motor chain, & the gears under the clutch cover, not to mention every bicycle owned by myself, my wife's & my children's bicycles. It truly works!
