Centrifugal clutch stuck engaged
Seanik
I have a Titan XC50 4 stroke from Dax and the centrifugal clutch is stuck in the engaged mode. Never had one off the engine before. Is there anything specific I should look for when I remove it from the engine. The clutch housing seemed to be hot when this happened. If the repair is complicated is the best course of action to return to dax for repair or replacement. Your thoughts and advice is sorely needed, I already miss my rides on the point beach cruiser.
Seanik
I emailed Duane at Dax and viewed his video clip per his instructions. It was a broken spring holding the clutch shoes. I ordered a set of three today from Dax, problem solved and fix on the way.
Thanks,
Seanik
