vintage97302
**This could be that it has nothing to do with the carb at all, that it is just harder for the engine to ignite the cold air-fuel mixture with a cold cylinder and piston. I might be expecting it to just fire right up when it can't while it is cold ( in Oregon it hasn't gotten much above 55 degrees ), being impatient might be the problem**
____________________________________________________________________________
First, I have looked through the topics on here searching for this exact issue and was unable to locate an answer, so here goes: My bike has been done for less than a week now. I am running the typical 80/66cc Grubee Skyhawk. I replaced the Chinese spark plug that came with the kit with a NGK one.
My problem is that the first time that I try to start the bike ( only when it is a cold start ie starting it the next day ) I have the choke set right, the gas is on...I get good peddling speed, let go of the clutch and give it some gas...it begins to chug. Now not " that the motor is having problems kind of chug " but that the clutch is grabbing king of chug. Then it dies and I end up wearing myself out repeating this process over and over again until finally it does what it should have the first time, lights up and goes.
Is it just because it is cold and nothing more serious??
Thanks...Eric
Thanks...Eric
