Shorty Frog
hey all, ive got a 66/80cc chinagirl, had for 2 months, had constant issues. first after less than a week my magneto died, a week after gettin the mag replaced the cdi wire boot vibed loose, lost brass retainer and spring-clip. swapped for a bosch plug end off a old chevy. 3 weeks later the front left mount stud snapped off while riding, lock nuts come loose, almost lost front mount clamp and rear come loose too, strapped it on with dog lead-wire(braided run-cable for pets) and limped 4 miles home. fuel tank vibrates gas out as i ride if i fill it ANYWHERE near full. now the carb been leaking gas from day 1, and now its worse, tried 2 gaskets and made 2 more to no avail. it appears the bowl teeters on the carb base, as if one is warped..bowl has been checked and is "square" at the rim area. carb body i havent checked yet. its the standard speed carb on the $150 eBay kits. i have so many issues idk what thread to add them all to, hence my threads seeming "rambly", so sry bout that. also had fuel flow issues;run great at start to 2/3 and at last 20%(wot) it seemed to bog bad,drilled larger jet=epic fail. soldered it closed as 2Door describes in a post. drilled smaller jet and is when i realised why a tank of gas(2L) was gone in 30-90 minutes sittin or ridin if i didnt cut off tank cock(bad seat on carb/bowl.. so now i cant test smaller jet. idk where to start guys, and noone in the area here is hip to these bikes...no dang body. I am in NC, sea level approx., maybe 100ft at most above. run 93 octane at about 25:1mix. all counrty driving, 2-10 miles per trip, not daily yet cus i dont wanna walk back...Any comments, about anything is greatly valued mates.
