Having a little bit of a dual problem here. If I put my carb on, and tighten it down real good so there's no air leaks, its on tight enough that my slide can't move freely, and the engine gets stuck in full throttle. If i let the screw back just enough so the slide moves properly, everything works, for about 10 mins until the carb loosens up just enough, so that an air leak causes the engine to rev up real good, and wont stop unless i give it a good push back onto the intake pipe. I would like to be able to tighten it properly, is anyone else having a similar problem? What can I do to make sure the slide works properly when the carb mount is tightened.
Farthom
Farthom
