I've had this bike for a while and its run good but now when I ride it it will run well then bog run well then bog at top end of rpm range any thoughts on it
The float, white plastic donut, does not attach to anything. It is free floating but does push upward on a small brass horseshoe shaped part that in turn presses against a needle valve. As fuel level rises in the bowl the float lifts (floats) and closes off the fuel inlet to control bowl fuel level.The bike is a 2 stroke 48 cc Skyhawk I opened up the carb and my float is not attached to anything could that be the problem?
Then that is not 30:1 any more, unless it was 50:1 to start with.Cdi brand new spark plug connection good ran cleaner in fuel compensated with more oil
