Rockenstein
If you run into a situation where your engine starts to loose power or won't idle properly anymore something easy and quick to check off your trouble shooting list is blowby. Blowby happens when the piston rings don't seal the cylinder properly and hot combustion gases blow past the rings down the sides of the piston. An easy way to check to see if this is the cause of your woes is to pull your muffler off, roll the engine over and looking in the exhaust port inspect the area of your piston below the rings, if the area below your rings looks anything like what is in the attached pictures you've got blowby happening. I'll add that in most cases the exhaust side is the side that fails first which makes sense because it's the hottest and driest side. The only fix for blowby is to re-ring your piston and very very gently hone the cylinder...keep in mind though that every situation is unique. You'll have to replace the piston, rings and cylinder if you've worn it all out real good. Good thing is that rings are cheap, at the first sign of any blowby re-ring your piston and run the new rings in gently for a few rides. Providing you keep on top of things and use a good quality premix oil it's not uncommon to re-ring any small displacement 2 stroke 2-3 times before a new piston and cylinder is needed. The toluene based carb cleaners in a spray can will aid greatly in cleaning and removing carbon and other deposits from a piston you need to re-ring.
Cheers...
Cheers...
