Bike Peg Drive Easy Build
otis
just bolt a peg on the flywheel,flatten tire a bit and mount the motor so the pe rubs on the wheel , sold 8 of these already$$$$$$$
weedeater, or chainsaw motors, chainsaw usually goes better.You take off all motor covers you can,{plastics,recoil},you then use the threaded holes where they bolted into to fabricate mounts off of to the scooter,you make 1 mount at a time,basically get a buddy to hold motor in position {rubbing on tire,nice true angle ffrom peg to tire} and after boltin a piece of steel 2 motor weld it 2 the scooter/bike and you have your first mount,know drill bolt and weld more mounts{usually pieces of flat bar} untill solid, you should use all available holes and make your own if necessary, run throttle, pumpup tire, gas and go!!!!! I dont know how to put up pics help me. you can use different size pegs to tinke with gear ratio or machine your own in shop class, big profits sellin em$$$$$ hope i helped you get rippin this was my first ride i loved em donthave anyleft thouh.
