ezrider Member May 18, 2016 121 2 16 Indiana Jul 2, 2016 #1 Some say to spray a little carb cleaner, or nitro into the cylinder. Just wonderin which is the better of the two.
crassius Well-Known Member Sep 30, 2012 4,032 158 63 USA Jul 2, 2016 #2 depends on why you're doing it - if it is a non-starter and it's because the motor is full of fuel, then no priming is better for non-starter with dry plug, I usually just put a bit of fuel into spark plug hole
ezrider Member May 18, 2016 121 2 16 Indiana Jul 2, 2016 #4 Kioshk said: Have you tried the choke? Click to expand... Just wanna rule out a few things, then will check the choke again. _
