Belt Tensioner and Belt Guard
GAS+RIDEZ
Is possible to use both?mount today belt Tensioner the belt stop slipping quite,but when mounting the belt guard I went to run and crank collide with belt guard,:-|| somebody ride the belt guard and belt tensioner successfully?and Thank's
Hi Victor, just use the parts that came with the belt tensioner, remove the metal part from the belt guard.
didn't they send you instruction on who to install the belt tensioner?
Ray
Hi Ray,they didn't send instruction on who to install Belt Tensioner, I mount it without problems, the issue is with the Belt Guard,my crank hits the Belt Guard when pedaling.
It sounds like you'll have to bend your crank some, remove your pedal, use a long pipe to bend out your crank enough to clear the guard.
Thank's Ray,
But already solved, I made a hole in the Belt Guard where the screw got stuck from Belt Tensioner.dance1
