deacon
minor bike philosopher
Since I returned the HF 2.5 hp motor I reset the ebike and began to ride it. First of all I can ride it on the scenic trail. They don't allow motor bikes, but they never say anything about the ebikes I have ridden there.
So this is a fairly dull story but there is a point at the end.. When I rigged it, I set it up very simple and with only basic controls. A simple wheel on wheel motor with an on off switch. So I hung a couple of 12v 12ah batteries from the top bar and off I went. The round ride is about four miles from my house and down the part of the trail I like. I pedal assisted the drive and when I got three miles done, I had to push the bike up the last hill and it was very hard to pedal without the motor. The power was pretty much gone.
Next I added a second battery pack with a trailer and off I went. When I got to the point where I was about to tackle the last monster hill, I hooked up the trailer and off I went. made it home with no gut busting pedaling required. But pedaling the bike with the motor on the tire was still difficult even though the motor is supposed to have a freewheel.
So I rigged a lift for the motor and tried it again with the trailer in tow. Instead of pedal assisting the motor drive, I only used the motor when I was really winded or the hill was a gut buster. I got up the first of the final hill, inside the park, that almost killed me on day one.
By changing my riding habits, there was enough power to make that hill reasonably efficiently. So I went on and had only a minor gasping episode on the true gut buster hill. I even got home witth the pack reading 26.1 volts. Still enough power to help me if I had another hill to climb. I didn't use the reserve trailer pack at all.
So I told my wife I want to try that again and be sure that it wasn't a fluke if not I'll leave the trailer home. Off I went this morning. I got to the trail and discovered that I had forgotten to bolt the trailer on, so I was even more careful to only drop the motor when needed. I also used only the amount of tension necessary for the conditions at hand. I did the ride even more comfortably. I got plenty of exercise and the hills were tamed even on the big ole coaster bike. I got home with 26.2 volts on the battery pack.
Here is what is interesting. I know now how they can make those claims about ebikes and battery packs. Just make your test like I rode the park the last couple of days. Coast all you can, pedal when it is easy to pedal, pedal anytime the motor is on, vary the amount of performance of the motor to the situation. Do that and you can achieve maximum output from your batteries, even on a very low tech bike.
If I lived in a totally flat area, and i wanted to pedal most of the time and only kick in the motor when I had gone as far as I could go without working up a sweat. Then turn it off after I had rested and pedal some more, I could get the max from the batteries.
That is probably true of the 100mpg on the gas bikes as well.
