Back pressure
GoreWound
480
Canada
by leaving the cap on? lol
is there a reason you want the cap off? if you just want your exhaust to have a big pipe opening you would do better butting a wide tip over it and leaving the cap in place (you might be able to get one from an automotive store that fits)
you can also get more back pressure by having more pipe length, that and a narrower pipe.
if you are worried about the muffler filling with oil you can try and get the end cap so the outlet is at the bottom, that should help let it out.
frank66
207
canada
it will make the carb jetting incorrect likely the more u change it. the banana pipe without a silencer is ok but its missing 20" of pipe /so top end is worse than stock.
2door
Moderator
Staff member
16,302
175
Littleton, Colorado
Unless you live and ride in an unpopulated area maybe you should give more thought to the impact that loud exhaust will have on your neighbors and the hobby in general. The performance increase will be negligible but the annoyance factor will not do anyone any favors.
If you're looking for a better exhaust system and an increase in power you should look at some of the expansion chamber systems offered.
Removing the end cap is not the way to go for several reasons.
