twowheeledfox
Picking up a Briggs-style (actually Kawasaki) flathead 4.5hp 160cc motor in a couple days. It fits std. briggs mounts, etc. I have a bunch of bike frames and spare mounting bits and brackets everywhere, but no welder and can only afford limited welding etc. services. Some important questions:
would a mount that clips on to the frame and is made of normal steel be strong enough? My prototype uses two 1/8 thick steel clips that clamp the frame using bolts and have a mounting plate in the middle. It works for larger frames and the gutted briggs I already have seemed to fit okay.
how to make a clutch? I will need to have a disconnect for obvious reasons.
how easy/hard is it to stick a cvt on one of these? how much for a cheap cvt?
dunno if it's chain or belt drive yet, would prefer belt-to-clutch and/or cvt and chain-to-drive-wheel but can compromise.
how to figure out gear ratios? don't want to spend ages building this thing only to realize it has a ridiculously low/high ratio. i am thinking a simple drive system of just motor-clutch-drive wheel.
and just to throw something out there: those cheap little LED flashlights make excellent headlights. rode on my (push)bike at night with two of them mounted motorcycle-style on the bars and was almost brighter than the cars that passed me.
thanks.
thanks.
