Altered Occ
saetta
This is my OCC, built in summer 2009. I replaced the original forks with a set that has front brakes and a 20" wheel. Recently I switched the motor to a PK80 w/centrifugal clutch and a pull start. The pedals will not clear this wide motor casing so for now I have them both parallel to each other and then locked in place. They now serve as foot rests. This makes for a smooth ride and an easy take off. I also switched out the rear sprocket from a 44T to a 36T. And if the motor fails, I'll have to walk it home.
