frozenveinz
I just hooked up a little 33cc 2 smoker from a stand up scooter to run on 35 psi compressed air. Holy mother of carp. Me torque wrench measures 8 ft/lb at the flywheel, at zero rpm. I would say the max rpm on this bugger has now decreased to maybe 2k tops (With my current trigger system, the motor wants to go faster, but the solenoid won't open fast enough!). But the torque, oh the torque! I can only dream of what higher pressures will bring. Oh wait, I can test too!
When i first flipped the valve, the motor jumped in the air, and flipped once. I need to work on that.
No mods to the engine except replacing the spark plug with a 6v solenoid valve, and replacing the magneto with a reed switch. Wired it up with a 6v lantern battery. Oh, and i removed basically everything but the flywheel, crankcase, and cylinder.
Just did some calculations, and 8 ft/lb @ 2000 RPM equals 3.04 horsepower. From a 33cc motor. At 35 psi. Niiiceeeee
I shall try to plug the exhaust port, and use the intake as the exhaust for a longer power stroke, meaning more power. heheheh I feel like a little kid.
