salorr33cc
if you hold the magneto side crankshaft still at the 1 o'clock position of the woodruff key and turn the magnet CCW (to the left) is that retarding the timing ???
it should be cause that would be making it later for the pick up, just double checking brain fart,,, thank you for your help
The key way on these magnets is very sloppy on some engines I have found out, Mine is a 09/09/2015 ( the year is stamped on your stator on the coils)) SKYHAWK GT5 w/ 38mm stroke piston and ZAE80 connecting rod.
Because of the slop in key way some engines its been said that adjusting the magneto can make an engine a different animal and some peoples problems that seem unsolvable can be caused by this, worth a shot.
Engines like some retard timing at high RPMs..
