I was given a typical one wheel drive adult trike. I would like to install a friction roller drive for the front tire. the unit can mount on the fork or on the handle bar stem, even if I have to add a extension to reach the stem so the roller can touch the tire and lift off it. the system should be simple consisting of the unit, battery, twist throttle , charger either on or off board. a controller would be used only if the system requires one. no display. it should be powerful enough to climb hills and complete with all connections, cables, ect. the trike has a basket to store the battery, either lead acid lithium or li-po. model name and model maker please
