mogollonmonster
Micargi Mustang GTS
That's Dax FS80 w/RT head/NT carb
Manic Mechanic Hub Adapter -40t, countersunk
Gasbike Universal Motor Mount
Wald 13.5in Hi Rise handlebars (bikewagon)
Heavy Duty coaster brake rear wheel (SpookyTooth)
6v Sanyo block dynamo w/ halogen light (random bike parts)
Product notes:
Had I known MM offers universal motor mounts, with custom sizes, I'd have ordered from him, and still may. The gasbike mount (as Motokity discovered) is too large a diameter for the bottom tube, and a bushing will have to be made. The MM mount would FIT.
The wheel ordered from SpookyTooth actually came from bikeberry. I tried to give business to an Arizona company, instead, those crooks at BB got my hard earned cash. Had I known aforehand, I would have gladly spent my money with Lynn at custommotoredbicycles.com where I would have received a much better product for the same price. I will not use or recommend SpookyTooth again, I was lied to.
The forks of my bike came out of the box FUBAR. One hole is drilled in the wrong spot, resulting in bad alignment of the spring with the center of the forks. The wheel is affected to a lesser degree, and I continue to seek remediation without replacement. It should also be noted that the forks are of obvious low quality and are noisy.
Duane builds fabulous motors, I have nothing but praise for him and his company.
Well...the parts are all in, I've stripped and regreased the wheelset, partially broke in the motor on Tanglebones, before his retirement due to metal fatigue. A SBP expansion chamber and a pair of heavy duty springer forks are in the works, and both time and money are trading places, as I seem to end up with one and not the other. Soon though, wrenches will be turned...
More to come, stay tuned!
Product notes:
I need three parts, a chain tensioner, fuel line, and fuel! Till then,
