49cc HS spark plug gap?
I can only assume that you are starting with a stock spark plug. The consensus here is to replace that with an NGK CR7HIX iridium plug.
If not, that is the correct gap. You could also try it a little 'tight', then widen the gap incrementally.
Good luck!
i like the stock sparkplugs. spark plugs are a comprimise between length/temp. the finer metals included. they all spark the same in the end. where the electrode sits is a comprimise of temp and performance.
deep electrode being the power giver but you dont want it to get to hot..
