4 stroke in Frame Kit
MB-Monkey
Has anyone had experience with this kit?
The Wizard 4-Stroke Bike Engine Kit
Specifications
Engine type Air-cooled 4-stroke OHV single-cylinder
Displacement 49.1cc
Bore X Stroke 41.8 X 35.8 mm
Maximum Power Output 2hp(1.5kw)/ 6,800rpm
Compression Ratio 7.4:1
Carburetor Float Type
Ignition Transistorized Magneto
Starting System Recoil Pull-Start
Fuel Type Regular Unleaded Gasoline
Fuel Tank Capacity .5 Gal (1.89L)
Lubrication System Forced Splash
Oil Capacity 8.48 ounces (250ml)
Engine Oil SAE 10W30
Air Filter Semi-dry
Throttle Twist-Grip
Clutch Automatic Centrifugal
Transmission Shiftless Reduction Gearbox
Final Drive Chain-drive
I like the all inclusive 4 stroke in frame look with a pull start and centrifugal clutch
