There is no differences in carbs 2stroke to 4stroke, excepting as I think is just is the throat size similar in range diameter. Is the physical connection going to work. Adapters are available from clamp to bolt on. Thread hole spacing on the cylinder or head where ever it be. Just because oil is mixed with fuel on the 2 stroke, I might see that it could be slightly more viscous. So a 4stroke carb would it get gummed up for maybe the jets are smaller? Anyway from what I've heard many 2 stroke carbs as labeled have worked on 4stroke engines. I would have actually tried, but I bout a cheap briggs carb. Unfortunately 20 or more years ago they were made with both low an high speed fuel needle valves, as current they skimp and don't. As the need for slow idle on like most lawn mowers, it does not matter. Governor only really just is for when going over pavement and transition to tall grass, so engine won't stall out. Actually I should say there probably are Briggs carbs new sold today that have 2 needle valve adjustment, but I was trying to save some money. The Briggs 25 dollar carb I bought 3 years ago is made in china, but the one mentioned many people use and it obviously too is made in china. I had a carb that was supposed to be similar to a Tecumseh. That clone was horrible though. The way the bowl and the main jet operated with some gasket that always leaked. I sent it back.
