Hey guys,
I put up the jack-shaft calculator again after cleaning out some hacked files.
The sliders control:
http://thebitstream.com/transcomp/
This is a calculator for regular jack-shaft, not a 'shift-kit'
How to use -
Set up up your sprocket and wheel parameters, choose the Nexus inter-3 or the iMotion-3.
Set your estimated stall/clutch-spring engagement RPM, your estimated peak torque, Horse-power, and max RPM.
Then hit the 'Start' Button for a simulated drag-race to max speed.
- Rear Sprocket- the number of teeth on the rear wheel hub
- Rear Wheel Size - in inches
- Output sprocket of the 3-speed connected to spoke/disc-brake flange
- Input Sprocket of the three speed - The driven tooth count of the 3-speed input.
- Engine Sprocket - NUmber of teeth on the sprocket of the engine.
- Crank to output Ratio - The number of rotations of the crank shaft to the engine sprocket.
How to use -
