I have cut the top off a yd100 jug, and severely modified the ports And case for the build. Using a minarelli jog head i cut to match at the moment as a test subject. Way to small for heat dissipation. 50m bolt pattern on the yd100 and the miniarelli head. I have never owned a 66cc or 80cc motor kit. Is the bolt pattern 50mm center on those for studs? Or 48mm? So many conflicting ramblings. I found few cnc heads i want to harvest and recut for this project for 66cc/80cc but before i go wasting 55$ on a head with bolts way to close "48mm" to my cylinder walls i figure i would ask! If not does anyone know a thick head with 50mm spacing? Cuttable material wise*
