crazyinsane51
I got this used engine and need some expert advice. Anyhow I can't get the engine to turn over fully using the spark plug tool on the sprocket. I can see the piston threw the exhaust port move up and down but when the piston goes all the way down the piston gets stuck and won't complete a full cycle. I also hear some sort of clicking sound then the piston hits the bottom. I tied to pour a little oil threw the spark plug hole and no luck and on top of that the clutch was slipping. Anyways this leads me to something in the bottom end of the engine is messed up. I was just wondering what the problem could be and see if it's worth fixing. Thanks.
