bigbutterbean
This happened as a result of a thread I started asking what would be the best type of generator to use for a charging system. A forum member commented with an offer of a free 12v bottle generator and charger from wonderful creations on ebay. I gladly accepted the offer and began making plans to build a charging system. My wife's brother in law also hooked me up with a power distributor with 5 terminals. The charger contains a recitifer, voltage regulator and fuse holder. The generator didn't come with any mounting hardware, so I came up with my own and the generator roller wheel sits on top of the rear tire. The charger has 5 wires coming out of it, positive and negative input and postive and negative output, and the 5th wire can be wired to a switch if desired. I cut the wire shorter and capped it with some shrink tubing pinched shut over the end. In the picture, you can see how the generator is mounted. The charger is the black box with the green/yellow led in the middle. To the right of the charger, you can see a small metal block with a clear plastic cover and red lettering. This is a Rockford Fosgate power distributor. I don't know the model, its not listed anywhere on it and rockford's website doesnt list it. They have updated versions listed, so this must be an earlier model. The input wire from the charger is normally connected to the generator, and the output is connected to the power distributor. Also connected to the power distributor are the headlight, brake light and battery. This way, the generator/charger will run the lights when the bike is moving, and the battery takes over when stopped. I am running a 4A fuse currrently. The charger is disconnected from the generator until my new 12v sla battery arrives. The 12v system can not efficiently charge the nicads wired in series that I'm currently running. The 12v battery will be here saturday.
