mrfubs
I needed somthing different to do so i decided to fab a 2003 yz80 expansion chamber to fit on my project bike. using the BernOmatic oxy/mapp torch i brazed the pieces together, overall turned out fitting great. I still need to fab 2 mounts on the frame for the 2 other exhaust mounting/bracing tabs.
flowported case and cylinder, cleaned up transfer ports, widened up exhaust and intake port, 3rd transfer port added, arrows reed block kit, cns carb #61 drill bit size for jet, puch 74cc hi comp cyl. head, ramped/notched/window'd piston. still in crank balancing process.
2 vids of it running w/stock exhaust, will post updates of yz80 exhaust when i can.
http://www.youtube.com/watch?v=ZrQ38tbUd20
http://www.youtube.com/watch?v=wKmmRpmGT2g
