Quick fix for oval tube frames
maniac57
Oct 8, 2011
4,484
22
memphis Tn
Get two long bolts and two coupling nuts and lock washers. Thread the nuts onto the bolts and install the bolts all the way into the motor. Then tighten the coupling nuts as needed. You can remove the extra length of bolt with a grinder if you like, but I didn't bother on the Pig.Cost about $6 bucks at Ace hardware.
