That's just where mine happened to be after proper adjustment. You can tighten your cable to the point that it won't happily spin the wheel when its off the ground.
Where the cable goes through the adjuster bolted to your case, it will thread out to give you alot of adjustment. With the kickstand down, and the motor idling, lean the bike so the tire's off the ground, and crank the adjuster until the wheel stops spinning like crazy. And check to make sure it bites good with a ride after that. If it doesn't bite good, you'll have to let off tension until you're happy.
The adjuster on your handle will give you 'on-the-fly' adjustment for when you're out-and-about, but I don't recommend turning that out too far because the little aluminum adjuster will spread over time, but it is good for some. I leave mine out a couple turns for when my pucks wear enough to start to slip, so I have that turn to get me home happily.
Remember, there's only 3-4mm of play in the whole clutch assembly. A little adjustment can do a lot.
That was the short term fix guys. Now down to the Brass Tacks. Over time, undue tension on your cable will cause stretching. That means that over time you'll be constantly fighting that stretch and keeping the clutch in the 'sweet spot' Hopefully you've heard that you should rest your bike 'in-gear'(handle released) so the cable doesn't stretch, right? ...Right?
Now you need to read this a couple times:
http://motorbicycling.com/f30/clutch-cable-clutch-adjusting-procedures-motorized-22729.html
Now you've got a better idea of what's going on, and there's no excuse to zip-tie your handle so you can pedal!
