UFOskeptic
Hello everyone: I just installed a belt tensioner kit from Tiawan for tensioning the belt from the flywheel to the clutch pulley on my Whizzer NE-5. Interestingly, the bearing that holds tension against the belt, slides up and down within the slot on the bracket, which defeats the purpose of the tensioner! I took it apart and it appears to be this way by design, however, the instructions tell you to tighten the 14mm bolt while holding the bearing down against the belt. I sent an email to the outfit in Tiawan, and it came back the same, that the bearing bolt should lock into position when tightened. Anyone installed one of these kits? The gap between the flat washer under the 14mm bolt and the gold washer (on the other side of the bracket) is big enough to prevent the bearing from being clamped into a locked position. Any help would be great! Thank you. "Loose Whizzer Belt John"
