Using unreeded HP carb set up... On non window piston and cylinder of same size
Wevil Kenevil
If I took a pk80 wildcat motor and removed the window piston and the ported cylinder and replaced it with a regular cylinder and a regular piston, would I still be able to use the Pz20 carb?
Without the reed box of course.... It seems like since they're both 47 mm piston that the carburetor should work on both but probably not because of the porting on in cylinder changes the combustion and all that kind of stuff so **** I don't know I guess I'll just have to try it.
Yes I can I just had to buy a short manifold that bolted from 47 mm to 40mm. . I found it on eBay and Amazon and a couple other places.
