rohmell
so does that mean the clutch is operating correctly? if so, then why is it so noisy? today, it wont start at all. when i pull the pull start with the back wheel lifted up, the wheel moves when i pull the rope. it makes a whining noise like something is grabbing too hard and not letting the engine turn over. it makes the same noise when i roll the bike forwards or backwards.
If the rear wheel is turning while using the pull-start, then something is wrong.
The clutch shoes in the centrifugal clutch should be retracted inwards, allowing the pull-start to turn the crankshaft only, and not the bell, or the rest of the system.
When the engine is running and at idle, still the rest of the system should not turn. Only when you give it gas, the engine speed will increase and the clutch shoes will move outwards and grip the outer bell, then everything will move together.
