killercanuck
Okay, a little preface before I get into this. On one of my bikes for the past couple of weeks I've been fighting some grinding on my clutch cover. The slop in my large gear was causing the gear to 'grind' on the cover at high rpm. I could clearly see where it was hitting the cover. So instead of replacing the whole clutch unit(and those 57-3mm bearings), I got out the Dremel and had at it. Just to give the gear more clearance, I added a couple more gaskets for good measure.
But I was still hearing the grinding sound.... So I double checked my cover, which I permanent marker'd the inside(after dremel) so I could see if it was still hitting, but there wasn't a scratch.
Uh Oh...
Plus I was starting to lose power...
Double Uh Oh!!
So I decided to pull my head off and have a look:
Aww Crap! What are those dings in the head from!!??
So off the jug came......
Good lord almighty! There was a 'little' play in the wrist pin, and I say little like mount Everest is a molehill:
It spun from here:
To Here!!:
That ain't right, is an understatement.
So I got the wrist pin out with a little persuasion and...
The bushing was completely gone! And it still ran! Not well, but it got me home...
And all that play caused the piston to chew on the transfer ports:
And both sides of the piston:
I'm baffled that it still ran.
So anyways, I know I'll at least need to replace the top-end. But how much lateral play should there be in the connecting rod? I've got about a 1/4" side to side at the top. Should I just junk this engine? Or is it salvageable if I can get the bushing chunks out of the bottom end?
Uh Oh...
Double Uh Oh!!
It spun from here:
To Here!!:
