H.P carburetor suggestions
Fizzbane
73
Canada
is it going to give an extremely large and noticeable difference from a stock carb? I got a stock carb with a K&N air filter atm.
Fizzbane
73
Canada
MINI MOTO 19MM PHBG DELLORTO STYLE CARBURETOR CARB CAG - eBay (item 230387945589 end time Jul-10-10 09:18:22 PDT)
LIKE THIS ONE 19MM?
"HKMOTORS" hmmm.... hong kong motors... where have I heard of chinese engine parts before?...
but seriously, that is a pretty nice price, any one had experience? tmcbroo?
moronic_kaos
225
Connecticut
I think your going to have a **** of a time trying to clamp that carburetor to the intake.
Check out the way their's are:
http://shop.hkmotos.com/images/19mf.jpg
Looks to me as if the carb fits inside the intake, the intake is made of rubber, and is meant to clamp down on top of the carb (like inside-out of what we've got).
Might have to cut some slots in the part of the carb that clamps around the intake to make it crush. And with this system, there's no guarantee that they made the inside of that crush fitting on the carburetor right to begin with, since it doesn't need to crush anything. Might be off enough to make the whole thing not fit together. If you screw up trying to dremmel it out your gonna have a heck of an air leak.
If you're gonna spend $50 on a carb, save your money & get something more like this:
http://www.treatland.tv/dellorto-SHBC-carburetor-p/dellorto-shbc-19.19b-carb-19.htm
Or this:
http://www.1977mopeds.com/product/940/Dellorto-PHBG-19mm-AS-Carburetor--Leftside-Controls/
Maybe someone could input on the filter, or maybe you could find a nice combo on eBay.
wildemere
269
Newcastle
That HK carb will probably set up for a 4 stroke, my 19mm clone was.
A 2 stroke emulsion tube or modding the existing one is required.
It will also need a smaller main and pilot and a rubber adapter for the manifold.
If you slide it on the HT manifold the choke circuit gets blocked off.
They are not easy to tune and make the bike thirsty.
But when set up the performance is good.
DanielMaia
309
Portugal
Talking about High performance carbs,
Anyone knows what is the limit of mm in this carbs to this motors? In some yamaha dt 50, some guys use mikuni 24mm, or 21mm, this type of lenght will be ok for this motors, or will be too large?
Mikuni 19mm are ok? easy to tune? dellorto 19mm?
wildemere
269
Newcastle
The problem with big bore carbs (over 16mm) is slow air speed though the venturi making for poor atomization of the fuel at lower RPM, This makes them hard to tune and gives poor fuel economy. They do work well at the redline at the expense of fuel consumption.
I can get over 80 miles range with the stock carb, it drops to nearly half of that with the 19mm Dellorto PHBG clone, depending on riding style. This is with a properly tuned carb, shaved head, port matched manifolds and opened up stock pipe, 66cc at sea level.
A 16mm throat size is the sweet spot for a stock 66cc
A 14mm would suit a stock 50cc
When selecting a carb make sure it is setup for a 2 stroke.
There are differences in the emulsion tube and slide cutaway.
A 16mm Dellorto SHA is a good choice for ease of setup or get the bigger PHBG if you have the time, tools and skills to set it up.
Run it lean once or twice and you will cook the engine.
The dellorto SHBC looks interesting, It looks like an updated SHA, anybody tried one?
DanielMaia
309
Portugal
In my motor i have:
Expansion chamber
Special Head design, sparg plug @ 45º
Intake port matched
NGK Iridium
I have here in portugal some guys that sell mikuni 19mm at a good price..Do you think 19mm is too much for this motor with this parts?
Thank you for all,
Daniel Maia
[EDIT] I tried a Bing18mm from a kreidler florett, and it was simply amazing, goes @ 50km/h up hill...but i noticed that it needs some tuning, expecially the low range and mid range.. the high rpm it was amazing..
moronic_kaos
225
Connecticut
The only thing that really makes a carb HP is the port size & amount you can adjust it, and the ability to add a decent air filter.
Check this out:
CNS Carburetor
I'm sure you've all seen them before, but spookytooth has a great write-up about it. Says it has the air/fuel adjustment screw, and it's only $50 and comes with a filter. Not to mention you'll know it goes on the bike because... it's built for it.
DanielMaia
309
Portugal
But, i have a problem..
The shipping cost of that CNS carb, to Portugal...is a lot expensive..
Someone here tried dellorto 19mm or so? I heard that dellorto are a little difficult to tune..
moronic_kaos
225
Connecticut
My old Dellorto 14.12 that came with my Tomos didn't have a way to tune it, not even a c-clip or anything. Just have to get a whole range of jets to go with it, or try and drill/solder them yourself.
Of course, those are the cheap-o carbs. The nicer ones have an adjustment screw.
Extinction
7
Estonia
I just put a Dellorto PHBG 19 on my russian engine with reed intake. At first I noticed that the motor starts better and throttle response is quicker although my new manifold is a bit longer. Performs well, I have had no time to get to the fine tuning but it runs fine atm. It also sorted the fuel flow issues, with mikuni at full throttle the mixture was ok for few seconds then got lean no matter what jet or float level I used, now its stable. :) I'd say go for PHBG.
motorhead419
ohio
I use a 18mm Mikuni myself. They are one of the easiest carbs to tune and parts are available everywhere. Get a straight intake from Pirate and port the hole bigger for the bigger Mikuni. The stock throttle cable works. All's you have to do is make a little adapter for the carb to mount to the intake manifold. I will tell you the jet sizes you need. Mikuni's are a tuner's carb.xct2
foureasy
478
tucson
24mm flatslide. awesome performance on a nasty motor.
dellorto 16/16 works the best as a bolt on carb for sure though
