Ernst
Bicygnals are a wireless combination light kit for front and back of our bikes.
Standard features are (wireless) Turn signals with manual settings for front white light and rear red light which can be set to steady, flashing or off while the turn signals still function.
Bicyignals "Indicators" Review
Here is a link to the Bicygnals page BICYCLE LIGHTS :: LED Torch :: Cycle Helmets :: Bike Safety :: High Visibility :: Online Shop :: Special Offers :: Competitions :: Bicygnals They have more products than the "Indicators" that I have.
First off this is not cheap. At around $70 U.S. plus shipping I ordered one.
The easy description is that they look cool as cool can be and I have not seen nicer looking turn signals so far.
The hard description is that theft is a constant worry since they do look cool and cost $70 plus shipping.
From what I read on the comments of others including a young girl reviewing for her friends on a bike site I don't remember the name of is that mounting may be a creative act. She attached hers to her book rack with cord. I drilled and mounted mine with a bracket I bought at a hardware store.
Some will be able to use the seat post mount and in that case the provided rear mount is quality and well thought out.
http://www.youtube.com/watch?v=XX6zw5_ph3s&NR=1
Front mount requires some bar space and I added a Top Peak bar extender Amazon.com: The Topeak Bar Extender: Sports & Outdoors
The "Indicators" is a slick looking unit and has it's own bag that looks cool as well with the Bicygnals logo on it. Just be careful with the zipper since it can come undone from it's track so don't force or rush zipping it up or unzipping it to keep the bag nice. It looks better with the bag intact in my opinion and stays together in a back pack for example.
Once you have mounted, as you see fit, the two ends to your bicycle you will see that they "snap" in place on a tab which you can depress to remove them. However, additional security can be obtained with carefully drilling a small hole in the tab for a "hitch pin" which I picked up at my local hardware store. Add a chain to that hitch pin and it can dangle free when not in use and stay on the bike. I added the hitch pins with chains.
Now The unit is wireless for the turn signals and manual when selecting the front and rear light functions but the turn signals are a bit different. The way we get the front and back to work together is a bit awkward. We have to put the batteries in at the (relative) same time so the front and back units will synchronize. When I see this happen I think of robot love or some such android thing. These two do a light dance and must be deciding on how they will talk to each other.
So getting the 4 AA's in the front unit and 4 AAA's in the back unit and "snapping" them in place is a bit of an awkward thing. More than once I have had batteries flying out or have failed to get one or the other to snap in.
So what happens if they are not synchronized?
They fail to communicate for one and also will turn off or go into "emergency flash mode" (rear) where all LEDs flash at once.
Basically the front will work for a few minutes and then turn itself off and the rear will flash all LEDs and turn itself off.
While I admire the non-functioning for those who may steal bicygnals and who do not know how they work it is a pain in the butt to worry if the signals are working and they sometimes stop communicating from what I can tell.
Now I cannot see easy if the rear turn signals are working in the daylight but I can see the front easy enough.
I have synced these only to find the rear has stopped signalling a turn. Why the failure? I don't know but it concerns me enough that I find I need to stop and check at times.
What could be the issue? Well perhaps some sort of radio interference has caused problems or even the light has jiggled enough to cause a disconnect in the battery case?
Well in an ideal situation the "Indicators" are excellent and classy. I have no complaints on the looks and the functionality.
There are some concerns with the behaviour and like I would expect of an intelligent device th behaviour is like coming to understand the ways of a new friend. An electronic friend.
I give this unit "Indicators" 5 out of 5 stars even though I have some issues with the rear turn signals failing to signal at times. It seems it is not a failure of the unit but some environmental aspect of things.
On the issues of synchronization I give this unit three stars out of five because manipulating eight batteries is not easy to do at times. I may seek to power both externally as a modification so that synchronization will happen when I turn the power on for both but I admit I am not sure if that is such a good idea since I am unsure about the rear power indicator working properly. I'll have to think about it.
Something other than having to open the battery case and remove and insert all 8 batteries at the same time needs to be done. I envision some momentary contact switch handling the electric disconnect rather than having to remove a battery every time I need to resync these two.
I am open to suggestions.
All in all these "Indicators" are classy. Combined with a modified Maxxon brake light I have a fully functional "highway" bike.
Other than still learning the behaviour of these I recommend them for those considering turn and running lights.
The synchronization and failure to communicate are things that bother me but I am certain it is not a flaw in the engineering. I feel it is a mater of coming to understand why and how these things happen and coming up with a coping solution.
If anything could be improved the need to open the battery case and pull the batteries then reinsert them together with the front and back at the same time could easy be replaced with some sort of button. Perhaps a dumb thief will find their new "lights" worthless not knowing they need to resync nearly each use but the smart thief will just look it up on the internet.
All in all the battery manipulation thing isn't protection from theft just a hindrance for those too dumb to read up on things. I hate playing "fumble fumble"each time I want to use my lights. Having to open the battery case each time also concerns me since at some point I will brake some part of them I am sure.
So if you are looking for a cool turn signal /front and rear light unit Bicygnals "Indicators" unit is a fancy solution. One that adds more cool on top of a cool build for sure as well as functionality in traffic. If we can just count on the rear unit to keep in communication at all times.
I'll be giving these things some thought and I will share what modification I make if I make them.
So, Thumbs up for this company.. Have a look for yourself and feel free to follow up with your own review.
Video link http://www.youtube.com/watch?feature=player_embedded&v=SwdCvPPO0NM
