anyone think about using the sprocket as the brake disc also like they do on modern choppers?
You got dialed in man. After seeing what you have for tools to work with, I would like to see what you could put out with a full shop.You rasied the bar here in Denver. Thanks again for the parts. the chopper is back together and running.
George
Okay, now I'm jealous. I'm going to pick up a small sprocket from Duane and start playing again. My previous attempt might have worked if I had wanted to fudge a little on pad/rotor contact area. If I went for full contact the caliper and chain would touch. If I go to a smaller sprocket, something I've resisted because of my hilly neighborhood, I might be able to squeeze it all in. I want to see Frank's set up first and see what he did for a caliper bracket.
sweet...ive got the clearance as well with my 36....ill be ordering the parts i need next week lol....looks good man...glad to see you got it worked out...my ironhorse has the clearance too im pretty sure
