Flip Flop Locking Question
tolemo
9
W Texas
Just found your thread while searching for info on the Thruster fixie. Locktite red or the(permanent) industrial shaft locking green may be good for your situation. No mixing and I've found it to be easy to use....Looking forward to your progress.
xetaprime
47
florida
Thanx tolemo, afraid I bit the bullet and drilled three holes between the sprocket and the hub, then JB Welded all threads and holes so it's on perhaps forever. The reason I did this was because the Quando hub as reviewed by some bicyclists may strip under pedal power even :0 We'll see. Tomorrow I'll be mixing gas and giving her a first go. Fingers crossed x infinity.
Regards,
Xeta
T13
3
New York
I know this thread has been dead for a while but I am doing the same install on the same bike and wanted to know how it worked out/ what ultimately ended up being the solution. Any help would be greatly appreciated.
Nashville Kat
1,503
55
48
Jacksonville, Florida
I have had good results bolting to a flip/flop-
you need a large flange hub with smooth undrilled sides, so you can drill the six hole pattern- and of course the sprocket has to have that pattern- it helps to have one with that already- if steel especially- because that's a tough drill-
the alloy hub on the other hand is easy- and plent strong- the six holes constitute less metal gone than most pre-drilled patterns. Here's my thread on it.
http://motorbicycling.com/showthread.php?t=24770
Of course, this doesn't freewheel- Boygofast on ebay sells a freewheel sprocket and huibs, but then you need a pull starter, centrifical clutch, and then wider cranks
With my set-up, if you use a 415 Trike chain, the pedalling resistence is minimized- really not too shabby-
I've thought about posting a thread
"I'll bet my motor bike pedals easier than your pedal bike!"-
that would apply to quite a lot of bikes out there at least
heres a great inexpensive 34 alloy sprock with the six inner drillings- a 66 should pull most riders on street use, if running correctly otherwise and not too massive climbs. I can cruise at 30 still not wide open throttle.
http://www.ebay.com/itm/34-T-Sprocket-Bicycle-Engine-Kit-Motorized-Bike-/120873449494
This thing is featherweight- get some M5 x 20/25 TITANIUM bolts and you've save a ton of weight compared to a kit set-up.
good luck
