9 volt led light mod
diceman2004
i thought i would share this with yaz all ( heres how i modded my light )
i had an chrome 12 volt tractor utility light kicking around and i stuck it on my Hawthorne , cause it looked real good with the new springer front end . ( problem , its a 12 volt incandesent car bulb )
so heres what i did
1-the bulb
2-the connectors on the bulb ( thin metal , molded onto the glass )
3-after filing thru the connectors and using sand paper to smooth out the holes edges
4-then i drilled the housing for the switch
5-2 superbright white LED bulbs mounted on perfboard to match the hole in the glass bulb
6-fitting the new bulbs into the glass lens
7-the assembled light
8-the light turned off
9-the light turned on
10-light on bike turned off
11-light on bike turned on
there ya have it
thats how i turned a 12volt glass incandesent tractor light into a cool 9volt LED light for my bike
its not the brightest ( with only 2 LED,s ) but it does the trick .
the problem with LED,s is that they project about 90 percent of their light directly forward , due to a built in lense in the LED itself .
to put a bigger array of LED,s into that lense would require cutting a bigger round hole thru the glass ( a dremmel with sandpaper drums would do it ( but i don,t have a dremmel )
i did aim the light in my garage , and it gives enough light to see by
i,m pretty happy with the way it came out
Just thinking,,,,If a small mirror were placed in front of the led would it reflect against the silver inside of the headlite and back out for more dispersion of lite ,,Dental mirror,spot mirror
That's really a great idea using an old light with the led bulbs. The larger headlight is a good idea because some drivers think that your on a small motorcycle. The look is really retro to me, very cool looking even when it's not on it looks good. Well done.
