I have a dilema about which hub I should go with on my mongoose mountain bike. I have a sbp shift kit and currently a 7 speed cassette, but I want to try swapping the jackshaft chain to the inside of the final drive chain and having only 5 speeds. If I change the hub out for an old narrower 5 speed one fitted with a stronger & longer axle and with extra spacers fitted to the left side of the axle, the advantage is that I'll be able to use nearly equal spoke tension. If I stick with the 7 speed cassette hub and just don't use the first 2 gears I'll be able to easily pick and choose all 5 gear ratios independantly of each other and know that the right hand wheel bearing being further out is a stronger set up and that sealed bearings aren't gonna need servicing as often... hmmm thoughts anyone?
