The Schwinn Riverside with 79cc predator
BelayBoy
159
illinois
currently communicating with Lynn, will see if she has some good idea
http://custommotoredbicycles.com/1inch_forks_springer_choppertriple_treedisc_brake
edit
ok so Lynn has headset will order the kick stand also
edit
nope after further conversation with Lynn, as far as she knows, she does not have any conversion headsets that will work on my bike. she suggested to purchase different sizes and try it out.
BelayBoy
159
illinois
next ape hangers, banana seat (i'll build my own and mount it on the rear rack) , maybe gas tank can't decide to go with WHIZZER STYLE or barrel
BelayBoy
159
illinois
here is something interesting, my schwinn riverside had 1 pc pedal crankset
"The thing to note is that there are several different 1 inch headsets. The one you need is probably the BMX/OPC assuming that the bike you are using has a one piece crank set? If you bike has a 3-piece crankset you would need the 1" ISO headset."
http://motorbicycling.com/showpost.php?p=193647&postcount=2
BelayBoy
159
illinois
After further investigation it is imposible to install 1.125 fork on this bike
The outside of the cups is 1.189 or 30.2mm. So moving on
Got this reproduction fuel tank
Anyone purchased one before? will I make mistake
edit
it has dent by the edge under letter W, may leak
BelayBoy
159
illinois
BelayBoy
159
illinois
i purchased this torch kit long time ago, didn't even know i purchased it but whatever
http://www.menards.com/main/tools-hardware/power-tools/welding/mag-torch-propack-torch-kit/p-1509565-c-10163.htm
i got some alumiweld rods from harbor freigth
so the other day i went to Walmart and purchased aluminum cookie pan
http://www.walmart.com/ip/Wilton-11x15-Sheet-Cake-Pan/10542183?action=product_interest&action_type=title&placement_id=irs_middle&strategy=PWVUB&visitor_id=51660467821&category=0%3A4044%3A623679%3A133020%3A420080&client_guid=0234feb0-44ce-4040-a1af-5a8967ebecc6&config_id=0&parent_item_id=10542190&guid=19b8a0bd-a325-431b-857b-e66e5d15f069&bucket_id=000&findingMethod=p13n
i wondered if i could build solo seat out of it or better yet gas tank
would add caswell epoxy liner inside of it
did anyone try this before?
culvercityclassic
3,115
177
Culver City, Ca
That is a very hard trade to learn but if mastered a good one to know. The guy in the video has been doing it for 40 years or more and makes it look easy.
Any custom tank takes time. Let us know how it works out.
BelayBoy
159
illinois
thank you ccc i know you did you share of gas tank builds too,
i'll try to build small box first and see how it holds up, will never know till we try it :)
will use lot of acetone
aluminum is expansive here in chicago
MotorBicycleRacing
5,844
109
SoCal Baby!!!
www.facebook.com
Build a seat or a gas tank outta this? laff laff
You musta lost your cookies but it is actually a sheet cake pan. rotfl
BelayBoy
159
illinois
currently looking into making Apple juice tank, planing to hook it up on the handlebars
looking at this thread
http://motorbicycling.com/showthread.php?t=11720
and this one, Hi ccc
http://motorbicycling.com/showthread.php?t=25702
while
https://www.youtube.com/watch?v=uWu4aynBK7E
also before i forget
that menards Mag-torch Propack Torch Kit sucks! fn waste of money
got to purchase bernzomatic torch, kind of looking into Bernzomatic TS8000KC Premium Torch Kit but something is telling me to go with Bernzomatic BZ8250HTKC Map-Pro Hose Torch Kit
already got some Lincoln Electric Welding and Brazing Flux,
and hf 90 Amp Flux Wire Welder
atombikes
525
Northern VA
If you want a good mapp torch, try the Bernzomatic JTH7. It is about a 4 ft hose, so the torch head is separate from the tank. It has a swirl head and truly creates a pretty hot flame. I have fillet brazed many bike frames together using just this one torch.
For flux, I use 20 Mule Team borax detergent powder mixed with water to make a paste. Yes you read correctly.
BelayBoy
159
illinois
Hi Atom buddy,
where do i get one? i thought bernzomatic discontinued it and instead they got Bernzomatic BZ8250HTKC Map-Pro Hose Torch Kit, cause of electric start or some thing, not sure why
20 Mule Team borax detergent powder, love this
edit edit edit!!!!!!!
i found the Model #: JTH7 BernzOmatic® Jet Torch Kit at Lowe's, going there tonight to get it "discontinued" sht out of luck A
atombikes
525
Northern VA
Hi Atom buddy,
I got mine at Lowes but that was many years ago. Not sure what it is about this particular nozzle design but it does work for brazing fairly well. I've even heated up lugged bottom bracket assys and pulled out the chainstay tubes. Gotta get pretty hot and a LOT of heat to do that.
BelayBoy
159
illinois
Finished removing governor and hanger rod, such a strange setup
1st removed flywheel and magneto
2nd removed the pin out of the hole and installed 1/4 - 20 x 0.5" bolt and red lock t.
3rd oppend the side of the block
4th pulled plastic governor and shim out
5th cut the hanger rod and removed it, the shim was attached to it. strange!!!! i thought the shim should be loose, i hope there was no third part besides shim and rod
- if anyone knows please confirm i don't want to start engine and get killed
6th threaded the hanger rods hole and installed the 3/8 bolt 1" long
7th closed the block and re-installed the flywheel & cup
Now I wonder is it only my engine that does not have any oil shut off inside of it or it is on all 79cc engines
the engine is soooo small, i think i made mistake by purchasing 79cc i should have gone with 212cc, dang it. side by side the 79cc vs 212cc not much difference in size. the only thing 212cc has is that plastic gear inside while 79cc has everything metal
BelayBoy
159
illinois
what kind of oil should i use for 79cc predator
the darn thing needs to brake in i am thinking maybe 10 30 Castrol, i think synthetic is not good for braking it in
