T t6R New Member Mar 31, 2014 80 0 0 Connecticut Mar 31, 2014 #1 Will this sprocket adaptor http://www.bikeberry.com/engine-kit-parts/performance/manic-mechanic-sprocket-adapter-assembly.html work with this mongoose bike? http://www.walmart.com/ip/26-Mongoo...gMethod=Recommendation:wm:RecentlyViewedItems
T t6R New Member Mar 31, 2014 80 0 0 Connecticut Mar 31, 2014 #2 I'm sorry. i put this in the wrong section, can this be moved to the right one?
2door Moderator Staff member Sep 15, 2008 16,302 175 63 Littleton, Colorado Mar 31, 2014 #3 The ONLY way to know is to measure the hub and know the inside diameter of the adapter. The measurement must be exact. A few thousands can make the difference if the adapter will work on the hub or not. Tom
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Mar 20, 2008 7,275 1,814 113 Los Angeles, CA. Mar 31, 2014 #4 NO, that hub adapter won't work on that bike.
T t6R New Member Mar 31, 2014 80 0 0 Connecticut Mar 31, 2014 #5 Venice Motor Bikes said: NO, that hub adapter won't work on that bike. Click to expand... Is this because it doesn't have a coaster brake? If so, is there a hub adaptor that would work with that style bike?
Venice Motor Bikes Custom Builder / Dealer/Los Angeles Mar 20, 2008 7,275 1,814 113 Los Angeles, CA. Apr 1, 2014 #6 t6R said: Is this because it doesn't have a coaster brake? If so, is there a hub adaptor that would work with that style bike? Click to expand... Yes, it's because that bike doesn't have a coaster brake... Just as 2door said, you won't know what (if any?) hub adapters will work until you measure the hub on the bike.
