Roll Your Own CDI
Are You Going to Roll Your Own CDI?
  • Total voters
    123
DuctTapedGoat
1,179
10
Nampa Idaho
I pulled one from an RPTV I was in the process of gutting after rohmell made a mention of it, but I need a CDI to be able to test.
I wish I knew how to test it with a multimeter to see if it would work or not.
Greg58
5,353
2,575
Newnan,Georgia
I hope you have better luck than I did with the flat panel monitor, no parts had a v rating high enough to be used for the cdi.
Ratchetbirds
125
Eastern Wash.
Yeah I was wondering about the flat panel montor stuff you guys were mentioning. I didn't take my old dead one apart because I figured it was low voltage throughout, except for the initial power supply. Now a CRT, that would have lotsa higher voltage stuff in it. Check some of your local scrap outfits, if they are like mine they have hundreds of CRT's and would be willing to sell you one for real cheap. Just a thought.
Ratchetbirds
125
Eastern Wash.
GearNut
5,104
11
San Diego, Kaliforgnia
After reading the Wiki on flyback transformers I can tell that they are a rising field type.
The primary winding is wound first with the secondary winding wrapped around it.
Collapsing field coils are wrapped opposite of that.
ducedave
370
4
18
Mentone Ca.
Hay rohmell good to see you here- I built me cdi but no fire I think I cooked the scr with the soldering iron pulling out of the downer board just going to replace it as every thing less check out right-as for pics that's depends on kids and their help with pic phones and so often with young ladies good luck! pulling them away from what ever their doing or avoiding doing so I don't know when pics will be posted zpt
ducedave
370
4
18
Mentone Ca.
I changed out the scr and it runs but I have way to much advance at idle on up what needs to be changed I'm guessing the 18ohm and or the 82ohm resister for a grater ohm?I'll file out the magnets groove and epoxy up the slack-I've started filing and checked it and it's getting better I'll finish in the morning should kick butt-after the timing is right I'll dial the retard if need be at the 2.2uf small cap with a 3.3uf or a 1.1uf
THANK YOU ALL AND A SPECIAL THANKS TO rohmell WHO MADE THIS POSSIBLE!
rohmell
1,531
6
New York
I am glad to hear that you have gotten your CDI running!
There are so many variables; magnet timing, type of ignition coil being used, etc, that you will have plenty of opportunity to experiment with different values and fine-tune your CDI for maximum performance.
In place of the two fixed resistors, you could try a variable resistor (potentiometer) to make it easy to experiment on the fly.
ducedave
370
4
18
Mentone Ca.
Dude you've been good to share your wisdom-I'm going to find the timing sweat-spot by moving the magnet then tune the cdi's curve from that point-hopefully I'll just have to fine tune one end of the curve the retard- 1 question though to get more retard would I go < or > the 2.2uf. small cap on the retard side or is it better to change out the 560ohm. resister < or > for now back to the magnet for me install and test ride time.zpt
it's getting closer,just a Little at a time.
Cagiva4ever
43
Finland
Hi ! people
Regarding these various cdi plans/files from web, has any1 happen to have the "Siliconchip" web sites mentioned magazine/files from "Programmable Ignition System from March, April & May 2007" ?
Silicon Chip Online - Replacement CDI Module For Small Petrol Motors
Regarding that cdi above, is there other upgrades to cdi designs than Thermistor, Potentiometer Resistor and Resistors for SCR malfunction back-up.. ?
any1 happen to know that is there many options on integrated/build-in timing light/strobo designs ? ive seen strobo on a hobby RC engine cdi instructions found from web.
im so intrested about all these Gizmos on cdi designs...
ive been reading so much during past 1 month but i havent found yet answers to those mentioned guestions.
bye:)
m
