Remote Air Intake
ferball
598
2
NH
I put a remote air intake on my bike today. The idea has been mentioned on many posts and most are much neater than mine but I figured I would post pictures and results. There was no noticeable improvement in performance, but was not expecting any, however it did change the sound a bit which was my intent. It was not much quieter, but the sound was lower, almost like it had more bass, so it was a nicer sound less like a chainsaw more like a motorcycle.
The set up itself was pretty simple I used the stock air filter and dremeled a huge hole in it, then I used an old inner tube to connect a piece of hose and a soda bottle, I left the stock air filter element in place, I may add a secondary filter element in the soda bottle but I did not have anything kicking around so it will have to wait..wee.
corgi1
2,272
3
KCMO
If you place a cloth (t-shirt )over the end then a flat pan bottom so that the air passes through the edge ,,how does its tone sound?
ferball
598
2
NH
Just an update I found that one of those swimming noodles cut to length fit into the soda bottle nicely. So I wrapped it in some cloth and jammed it in there and it quiets it down noticeably.
Venice Motor Bikes
Mar 20, 2008
7,275
1,814
Los Angeles, CA.
Doing something like that also lowers the performance of the engine, because now the engine has to work harder to pull in the air through that length of hose.
BarelyAWake
7,194
21
Maine
...if the ID of the hose is significantly larger then the throat of the carby there'd be little to no impact on performance, it'd hafta be awful long and/or smaller than the carb to effect it. I did a few with & without runs on my schwinn as I was kinda worried about that too ;)
ferball
598
2
NH
Seems to be running fine, but I may take it off just to test if there is a performance issue. I do like the new sound it makes though
