OK boys. I should be studying for an Electronic Theory final i have this morning at 10:00. But my priorities changed with lack of sleep.
SO without further adieu, here's the plan: Water Cooling
We have all experience the significant power gain associated with a cool engine. Right in between starting up and reaching running temperature i notice a 25-50 percent gain in power depending on the temperature and the engine. Which leads me to believe that if i was to water cool my engine, i might be able to retain these gains during my entire riding experience.
Personally, i run a pk-80 slant with no base or head gasket, an NGK BPR6IHX plug(the iridium one), solid copper core wire with silicone boot, SBP expansion chamber and shifter kit i got from a buddy, a Dellorto 16mm SHA carburetor with panty hose air filter and a homemade strait 3/4" long intake. I can go upper 35-40mph any day on flat ground sitting normally, in a crouch Ive gone 44 on a real cold day.
Now this thing gets hot, and when i say hot, i mean it really doesen't idle at all after a hard run and the lowest part of the crankcase, which should be the coolest part of the engine, is hot enough to burn. Though not unusual for most engines, the head and cylinder gets way past 212F judging by the fact that if you spit on it itl spit back
This is not to say that every engine has insufficient cooling, but im running out of things to improve on this thing, so i figured why not.
I had a 15 dollar gift certificate for amazon from taking a survey so i bought this 12 volt pump(Pic 1) for 9 bucks out of my pocket, it draws around 650mA under full load and delivers about 1.7 gpm at max output. Though its not important for this application it can also generate about 4 feet of head before its maxed out... even with both of the radiators hooked up in series it still puts out around .8gpm. Doing some very conservative calculations I think this should be more than enough flow, even though i doubt i will need both of them..
Then me and a buddy bought these two hydraulic fluid cooling radiators the black one measures 3"x8.5" and the silver one: 12"x5".
so now i had the hardware, no excuses at this point. Time to take off those fins. As a student at Virginia Tech, I'm not allowed to use any of the machining or shop facilities, apparently its a liability, but what isn't these days? But about 4 hours of sawing with a hacksaw blade(no handle) and grinding with a Dremel tool l(I HATE DREMELS!!!), and i had a virtually smooth surfaced engine. I wish i took pictures at this time but since then i've filled in all the crevices with epoxy mixed with some of the aluminum shavings resulting from all the cutting. also, i've added some epoxy impregnated pieces of manila folder to help direct the flow around the cylinder completely.
so from here, i plan on going home for the summer where i''l have access to my dads shop, I'm going to grind down the coolant fins so that they are a uniform quarter inch or so from the surface of the engine, then il use some removable filler material to fill all of the coolant paths, then i was thinking I'd make a fiberglass shell around the fins and remove the filler material which is yet to be determined.
So enjoy the picks for now, and as for the filler material, i was wondering what you guys recommend? Rigid foam is no good because its a pain to fit around the contours of this thing, i was hoping cured Gorilla glue was acetone soluble, that would be ideal, but online it seems to have mixed claims and i don't want to be stuck with a cylinder covered in urethane insulation. Bees wax would be good but i dont know where id get it locally. I was thinking butchers wax might be ok but it like a little more rigidity..... If anyone is willing to test that gorilla glue (Cured, mind you) in acetone that'd be great, otherwise il keep you posted and wish me luck on this exam!!!
