Hey all.
I figured I would jump to the 2-cycle section of the forums post introduction. There is some seriously cool machinery out there!
So, I have a Chinese engine kit. It's been sitting in a relatively safe garage for a couple years. Gonna put together a bike to bolt it to.
A few things I have been thinking about in terms of setup:
First, tear it mostly down. I mean yank off the head, and cylinder to inspect the top and bottom ends. Give the piston, and cylinder walls a thin coat.
Maybe run a little oil into the bottom end,and give it a few spins by hand?
Check the cranks seals (it does have them right? Never tore into something this small).
I was going to pull all the studs, and go with bolts to replace them, as I have read the studs have a way of breaking. Good idea? It's mentioned in the engine prep thread. What would be an ok torque spec? Anyone know? I wouldn't want to strip anything.
I have seen anecdotal mention of removing the head gasket, and just running sealer there. Good, bad, indifferent? Read these motors are generally low compression.
Gonna check what spark plug I have. Probably replace it, unless the kit came with an NGK. I don't remember. It's been a while. I moved out of my parents' place before this build project got off the ground.
I figure while I am at it, I should look at the plug wire coming from the coil. Read this is also a problem area. Probably cheap to replace. It really wouldn't surprise me if I could just yank a better wire off a car that I have yet to part out.
Dig into the carb, and check to make sure that the needle valve is set at the second from the top slot. Always able to adjust later. Better to follow the guidelines of someone who has done it before, than to just assume that the guys who assembled the kit cared that it was done right.
I know that even though this is a "new" engine kit (well, at this point, it is unused) it is possible that there may be some issues that need attention. I am a bit of a tinkerer by nature, and the money put into the kit is a sunk cost... so I might as well have fun with it. I'll either buy a cruiser to stuff it into, or see if I still have something around my folks' place to mount it to.
What do you think though...going the right direction/head in the right place?
