Hey everybody! After decking the jug by about .100", adding an additional bottom gasket, and re-machining stock cylinder heads to test different combustion chamber shapes, I decided to make a totally new head from 5 inch diameter round stock. Of course, it incorporates a squish band, which hopefully you'll be able to see in the photos. I deck the cylinder jug so that the edge of the piston is flush to the top of the cylinder, so basically, the gasket determines the squish clearance. After test driving it, I'm pretty happy about the power. The new head really seems to keep the engine cool, as there was no sign of detonation. In comparison to the stock heads with the high compression modifications I did made it so you could only go top speed for brief periods, before head temp. rose too high and then detonation would start, and I'd have to back off on the throttle. I'm thinking about possibly making some more for other people to try out. I just need to do some more testing to perfect it, if possible. I took the advice from some others on this site; I made the head so you could use stock studs and spark plugs.
-Fred
-Fred
